Flex 6300 to HL-1.5KFX connection
Doug Seyler
I just received the Flex-6300. It works well on normal power. However, when I hook it up to my THP HL-1.5KFX (ALC and PTT) it doesn't seem to key the amp. I am running the amp in manual mode for band. I have used this amp successfully with an Icom 756 so I know that it works. Any suggestions/hidden menu selections?
Doug WB5TKI
Doug WB5TKI
Have you gone into the settings menu and enabled the amp keying relay? Settings on top left of the screen. Jim K4JAF0
I made the same error with the 6300. Flex (foolishly?) paired the ALC with PTT in. The amp keying RCA is on the opposite pair of RCA's on the chassis.0
Thanks, that did the trick. The naming of the connections is very unintuitive!
- 631 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
