Home Brew BAND EDGE MARKERS
Simple way to create BAND EDGE MARKERS.
You can create markers anywhere you want with this method.
Following Sets a marker at 7.125000 The Bottom of the Extra Phone Band on 40 Meters
Simply put a TNF at 7.125000, It creates a YELLOW LINE, Then Remember the TNF
and the line changes to GREEN.
Now you have a visual marker at 7.125000.....
Any time you re-boot your Flex or add another Panadapter the Marker is there.
Ken W9IE
Ken W9IE
9
Pretty slick!1
I stick post it notes on my screen.1
This sounds much better than the white-out i have been using
Nice workaround.0
Hey!
What's the worry?
Everyone now a day is an EXTRA class!
Cynical and earnest too...
OK, I'm a rookie - what is TNF? (haven't got my 6300 yet) thx
TNF = Tracking Notch Filter.0
Alan, Tracking Notch Filters are filters that can be set anywhere you may need them
to eliminate a Bird or noise caused by outside sources.
You can also remember them so anytime you go to a band they are always there.
Look up the Official Description in the User Manual.
Any way, I just used that feature to leave a mark on the Screen at a Band Edge
so I had a Visual Indication.
Ken W9IE0 -
Neat idea. Still waiting for my 6300 but saving all these helpful hints for later. Thanks!
The same technique can be used to mark channels on the 60 meter band.0
This is a great work around, and I'll be trying it. However, it would be quite helpful for Flex to provide options that are both flexible and persistent. These should include settings for each class of license and mode. 60 meters markings were quite helpful in Power SDR. Certainly this should be established for all the countries using Flex. Other more subtle matters concern power settings and issues regarding locations. Alerting regarding signal width spreading beyond the band edge, LSB, USB, CW envelope, etc. could be incorporated. Again 60 meters is the most complex, in the US at least. Perhaps a clean Interface for the user to design her own is the way to go, at least initially. Visual clues such as cross hatching, colors, balloons with text, and even audio could be incorporated. Things that could also be included would be a means of marking the sub-bands established by general agreement rather than by law. The whole idea is to make it more certain to not only meet the regulations but also to keep specialized areas free of QRM. I've been a ham for 63 years, most as Extra Class, so I've seen a lot of changes. It's not a matter of people being lazy or ignorant of these details; it's a matter of assisting the best operating possible. The great thing about Flex is the almost limitless potential for such improvements. Perhaps someone will use the APIs available and provide a finished add on.
SmartSDR for IOS has the band plans as an option. This would be a great enhancement for SmartSDR for windows.2
- 340 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 918 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
