Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
Difference between Ant1, Ant2 and Ant3 connectors
                    Roger Sjölin
                    My FLEX 5000A has Ant3 connector marked HF/6m. Is there a difference between the 3 connctors Ant1, Ant2 and Ant3?
            The early 5000's with the HFRIO-27 antenna connector board had a recommendation that you only use ant 3 for 6 meter transmitting. The board was redesigned to HRFIO-34 with the advent of the second receiver, V/U option and ant 1-3 could now be used for 6 meters, http://kc.flexradio.com/KnowledgebaseArticle50057.aspx?Keywords=hf%2f6m+on+50000
            Thanks for the answer. Is there a simple way to figure out which hardware configuarion my FLEX-5000A have?
 /SA0AND
            PowerSDR Setup->General
 Under Flex-5000 config look for RFIO, board revision is in parenthesis.
 (27x) is old - 6m ant3 only
 (34x) is new 6m ant 1,2,3
            Also, if you have the 2nd receiver, you can only use ANT1 out of the 3. So I use ANT3 as the primary 1st receiver and Ant1 or Tap for the 2nd Receiver. 0
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 15 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
