SSDR V1.2.1 -- Enhance the FlexControl interaction with RIT/XIT
Problem or feature? -- The RIT and XIT functions on the FlexControl remain active once used, even after being cleared by double clicking. If you bump or move the knob, the RIT/XIT function will automatically be activated again. It's a feature if you like the way it works and an opportunity for improvement if you don't.
Idea -- when you double click to clear the RIT or XIT function, also turn off the LED indicator on the FlexControl and disable the function. See graphic below for more details on the problem and suggested solution.
Additional consideration -- If people are divided on how it should function, a "double click" check box option for RIT and XIT to "clear the function" could be offered. Another option would be to implement a "hold button" function that clears the RIT/XIT and also turns off the function.
In this example below the AUX buttons are assigned as follows:
AUX 1 - RIT
AUX 2 - Slice AF
AUX 3 - XIT
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
AUX 1 - RIT
AUX 2 - Slice AF
AUX 3 - XIT
Regards, Al / NN4ZZ
Glad to see I wasn't the only one confused by v1.2.1 RIT/XIT operation.
After 20 minutes of fiddling I discovered when you press the center tuning knob it resumes the slice tuning function.
Asher,
Yes, assuming you have the knob set to activate tuning (or some other function) on depression.
A caveat for using the knob depression is you have to be careful not to move or rotate it at all or it will re-activate the RIT/XIT first before assuming the new function.
As noted you can also deactivate the RIT/XIT function if you press one of the other AUX buttons assuming you have it set to something else (like tuning or Slice Volume).
Some people may still prefer to have the "double click" or the "hold button" function to do the clear and deactivate all in one step.
Regards, Al / NN4ZZ
Excellent idea Al. FRS what do you think?0
I am still dumb founded with the FlexControl. I find it to be a nuisance with some many things that it can do: I can not remember what I assigned it to do. For me this is just a space occupier on my desk.
I find my mouse to be more agile than this device. No is not for sale but, maybe in another year or so, I will learn how to use. I give it a thumbs down!
I agree with AL..My **** fingers are always bumping the RIT/XIT by 10-30 Hz whenever I try to press the big knob to return to tuning the main frequency dial. It would be easier to have the "Clear" also turn RIT/XIT off.
Hi Ernest,
I hear you, in a rush you can forget what button does what. I took a different approach, I have 2 FlexControl knobs and generally leave each one set to a specific function. The two functions I like to use the knobs for are: Slice tuning and Slice Volume. Like you, I prefer the keyboard, mouse and scroll wheel for most of the functions.
Rather than "pushing and clicking" to switch my RIGHT FlexControl back and forth from Slice Volume to RIT, I would add a 3rd knob if I could. If SSDR ever supports multiple FlexControls you have a buyer for yours (hihi).
In the mean time I'm just trying to minimize the chance for error and make the swapping as efficient as possible. This is not a big deal but maybe some others would like to see the enhancement.
Regards, Al / NN4ZZ
I like the double click option to cancel RIT and XIT.0
Ditto -- and would like to see "CW SPOT" added to the assignment list0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
