fldigi and CAT
DonS
Member ✭✭✭
CAT not working with fldigi since 1.2.1 upgrade. I have to initialze CAT on fldigi to get CAT working. This was a problem prior to fix with fldigi and SmartCAT. I will also post on fldigi site.
Working as before here. Did delete ports when I uninstalled everything prior to installing 1.2.1 & the new CAT.0
George,
That is also what has to be done with HRD too. I did exactly the same as you.
Make sure you are running Fldigi 3.21.80 or greater with the updated SmartSDR.xml file.0
runnin .81 of fldigi and had the updated version of the xml file. I also had to recreate ports with the update of SmartCAT0
I jst re-checked it out on my system and it is running fine. CAT initializes when ever I start Fldigi.0
I uninstalled SSDR , rebooted, and reinstalled and rebooted and fldigi worked without initialing CAT in fldigi.0
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
