fldigi and CAT
DonS
DonS Member ✭✭✭
edited January 2020 in SmartSDR for Windows
CAT not working with fldigi since 1.2.1 upgrade. I have to initialze CAT on fldigi to get CAT working. This was a problem prior to fix with fldigi and SmartCAT. I will also post on fldigi site.
  • George KF2T
    George KF2T Member ✭✭✭
    edited October 2019
    Working as before here. Did delete ports when I uninstalled everything prior to installing 1.2.1 & the new CAT.
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited January 2015
    George,
    That is also what has to be done with HRD too.  I did exactly the same as you.
    edited March 2017
    Make sure you are running Fldigi 3.21.80 or greater with the updated SmartSDR.xml file.
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    runnin .81 of fldigi and had the updated version of the xml file. I also had to recreate ports with the update of SmartCAT
    edited December 2016
    I jst re-checked it out on my system and it is running fine.  CAT initializes when ever I start Fldigi.
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    I uninstalled SSDR , rebooted, and reinstalled and rebooted and fldigi worked without initialing CAT in fldigi.
