v1.2.1 AF Input combo box inop?
Michael - N5TGL
Just loaded 1.2.1, and it looks great! Processor/DEXP is pretty awesome...really makes for some punchy audio. Noticed one problem though, the AF input combo box on the P/CW menu on my machine is blank, and clicking the button does nothing. Tried restarting 1.2.1 a few times, no luck. Attaching screen cap so you can see what I'm talking about.
I'm in the UK, so heading off to bed here shortly. Not sure if I'm the only one on this but thought I'd pass it along.
Shows normal here...0
Michael, Paul, which 6000 radios do you each have?0
My advice is to close SSDR, try a reset of radio to defaults by powering it off, holding down OK and then press and hold power until the countdown completes and release. If that doesn't work, with SSDR closed, reset client defaults by deleting C:Users<USERNAME>AppDataRoamingFlexRadio SystemsSSDR.settings and relaunch. This will reset your client & radio to defaults.0
6700 here0
Gave both of those a try, still same result above. 11:18 pm here so i'm off to bed. 5am comes early! I'll check in before work tomorrow to see if there's any other suggestions.0
Well, now it's there and I'm not exactly sure how I got it working. Did another reset/remove of the settings file and voila, it appears. Was kind of weird because after removing the settings file, it seems like it defaulted to a line in. I had saved my previous settings file, renamed it back, reset/restarted and it worked....or at least that's how I think I did it?0
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
