v1.2.1 AF Input combo box inop?
Michael - N5TGL
Michael - N5TGL Member ✭✭
edited March 2017 in SmartSDR for Windows
Just loaded 1.2.1, and it looks great!  Processor/DEXP is pretty awesome...really makes for some punchy audio.  Noticed one problem though, the AF input combo box on the P/CW menu on my machine is blank, and clicking the button does nothing.  Tried restarting 1.2.1 a few times, no luck.  Attaching screen cap so you can see what I'm talking about.
I'm in the UK, so heading off to bed here shortly.  Not sure if I'm the only one on this but thought I'd pass it along.
  • Paul Christensen, W9AC
    Paul Christensen, W9AC Member ✭✭
    edited February 2017
    Shows normal here...
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    Michael, Paul, which 6000 radios do you each have?
  • K6OZY
    K6OZY Member ✭✭✭
    My advice is to close SSDR, try a reset of radio to defaults by powering it off, holding down OK and then press and hold power until the countdown completes and release.  If that doesn't work, with SSDR closed, reset client defaults by deleting C:Users<USERNAME>AppDataRoamingFlexRadio SystemsSSDR.settings and relaunch.  This will reset your client & radio to defaults.
  • Michael - N5TGL
    edited October 2016
    6700 here
  • Michael - N5TGL
    edited October 2016
    Gave both of those a try, still same result above.  11:18 pm here so i'm off to bed.  5am comes early!  I'll check in before work tomorrow to see if there's any other suggestions.
  • Michael - N5TGL
    edited December 2016
    Well, now it's there and I'm not exactly sure how I got it working.  Did another reset/remove of the settings file and voila, it appears.  Was kind of weird because after removing the settings file, it seems like it defaulted to a line in.  I had saved my previous settings file, renamed it back, reset/restarted and it worked....or at least that's how I think I did it?
