fldigi- after MT63 mode switch, first transmission is garbled, subsequent tx are fine
Eddie Jennings
Hello,
I have been a VERY satisfied Flex 3000 owner for several years. I am an NMC MARS member- we use Fldigi/Flmsg/Flamp daily.
I've noticed a problem that occurs when I'm switching between MT 63 1K and 2K long. Often the first transmission will be garbled - sounds like skipping samples, while subsequent transmissions are fine.
I've also seen this problem, upon my first transmission with Fldigi. I have applied the recent Fldigi fix- I installed fldigi 3.21.79 and the new powerSDR.xml file. I'm using the legacy 1394 driver. I run Windows 7 Ultimate/64 bit.
I also use com0com and VAC 4.13.0.5811. I'm very pleased with the Flex and Fldigi, I use them both nearly every evening for multiple NETS.
Any suggestions will be gladly followed. I have configured my software in accordance with on-line resources, but I'm sure that I may have missed something.
respectfully,
Eddie Jennings
respectfully,
Eddie Jennings
Hello,
I would like to add some additional information to help troubleshoot. I'm running PowerSDR v2.7.2.
The transmission remains garbled throughout the transmission of the entire initial message, no matter how long.
From the garbled audio and spectral display, it appears as if the signal is low pass filtered
to below 1/2 the original BW, sounds like samples are dropped, and is not successfully processed by any receiver.
I don't remember seeing this problem prior to about a year ago. My detailed settings are:
Audio:
Primary: buffer 2048; Sample Rate 96000
VAC1: Windows Driver WDM-KS; Buffer Size: 2048, Sample Rate 96000, Buffer Latency 0 ms
DSP Buffer Size:
Phone RX/TX: 256,256
CW: 2048
Digital RX/TX: 256.256
CAT: Enable CAT on Port COM17, 57600 Baud, Parity: none, Data: 8, Stop: 1
PTT: Enable PPT on Port COM 16, DTR, ID as PowerSDR
VAC Control Panel Settings:
2 Cables
Up to Auto Worker Threads
Prio: 24
Connected Line Source: Line
SR 11025...96000 BPS 8 ... 32 NC 1 ..2
Max Inst: 2, MS per int: 1, Stream fmt limit: Cable Range, Clock Corr Ratio: 100
Com0Com: (CAT Port on Flex 17)
COM 7: emulate baud rate; COM 17: enable buffer overrun
Fldigi: User RigCAT
Rig Desc File: PowerSDR.xml; Device: COM7
Retries: 5, Retry Int (ms): 50
Write Delay (ms): 25l Init Delay (ms) 200
Baud Rate: 57600
Stopbits: 1
Toggle DRT for PTT
and Hardware PTT settings:
Device: COM6, User DTR
respectfully,
Eddie Jennings, AJ4OC, NNN0HBO/GBS
I'll try to replicate this, and let you know what I find. Usually I can send/receive MT63 without issues via Fldigi, PowerSDR, and my Flex 3000. I have not done it in a few weeks though. Andy NNN0OBY0
Thank you Andrew,
I found a new manifestation of this problem- NOT in Fldigi, but in RMS Express. If the first transmission is garbled, then all subsequent transmissions are an no connection can be made.
I then could simply exit RMS Express and try again, until the first transmission is not garbled.
When it system works it works flawlessly, which is most of the time.
Intermittently, I do run across long runs of failure. I was able to connect and check traffic today.
My Winmor WL2K settings are:
Radio Model: Flex radios
Antenna Selection: Default
USB Digital is checked
Radio Control Port: Serial COM7, Baud 57600
PTT Port: Serial COM6, Baud 57600, Enable DTR checked
WINMOR TNC Setup
WINMOR Capture Device: Line 2 VAC-eb
WINMOR Playback: Line 1 VAC-df
Any information is appreciated,
respectfully,
Eddie Jennings, NNN0HBO, AJ4OC
Noticed that the status was changed to "Not a Problem"
This is respectfully still a problem - no resolution has been proposed.0 -
I just learned on a MARS net that another Flex 3000 owner is having the same problem using Windows 8 with both Fldigi and RMS Express.
Any comments, hopefully more informative than, subsequent outside flagging as "NOT A Problem" are appreciated. "NOT A Problem" is more palpable with a short e-mail or other communication, respectfully.
respectfully,
Eddie Jennings, AJ4OC, NNN0HBO/NNN0GBS0 -
Hello,
Upon reverting back to VAC 4.11 and to the legacy 1394 driver, I have not experienced these problems with Fldigi nor RMS Express.
Thank you for providing me the forum for my issue and its RESOLUTION. In retrospect, it was not a Flex 3000 but an associated software compatibility problem. I hope this info helps others.
I use my Flex 3000 almost daily for MARS nets and have since 2009.
respectfully,
Eddie Jennings, NNN0HBO/GBS1
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
