6700 running smartsdr 1.1.3 hard of hearing at times..
NM1W
I had opened this topic for smarsdr 1.1.0, and it still present in 1.1.3;
The problem: I start up in wsjt mode on 10m. Sigs are down around -108, I operate for an hour making contacts and then notice the band seems to be dying.. but it isnt, the floor is now up at -88..
close smartsdr, reboot radio; start smartsdr.
Floor now -108 and band has plenty of signals..
operating env: win7 x64 w/dxlabs, jt65/jtalert
Similar, but very infrequent, problem with 6500. Cycling MOX or TUNE clears it for me.
Have not had to reboot. If this were an old-tech radio, I'd guess the ground side
of an antenna relay was intermittently stuck open.
I have this problem with my 6500 in the middle of a qso the radio goes deaf and several clicks of ptt or mox will restore the receive signals. It sounds and acts like the antenna does not switch back to receive. SWR shows perfect and transmit remains good.0 -
Same here with my 6500, a few clicks with the PTT and the signals come back (happens mainly on 75M, at least for me). It's a known problem, I assume it will be fixed sometime in a future update.
Tks Ned; I've tried both of those and neither gets it back..0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 938 Third-Party Software
