6700 running smartsdr 1.1.3 hard of hearing at times..
NM1W
NM1W ✭✭
edited July 2017 in SmartSDR for Windows
I had opened this topic for smarsdr 1.1.0, and it still present in 1.1.3;
The problem: I start up in wsjt mode on 10m. Sigs are down around -108, I operate for an hour making contacts and then notice the band seems to be dying.. but it isnt, the floor is now up at -88..
close smartsdr, reboot radio; start smartsdr.
Floor now -108 and band has plenty of signals..
operating env:  win7 x64 w/dxlabs, jt65/jtalert
  • Ned K1NJ
    Ned K1NJ ✭✭
    edited July 2017
    Similar, but very infrequent, problem with 6500.  Cycling MOX or TUNE clears it for me.
    Have not had to reboot.  If this were an old-tech radio, I'd guess the ground side
    of an antenna relay was intermittently stuck open.
  • ai6re
    ai6re ✭✭
    edited December 2014
    I have this problem with my 6500 in the middle of a qso the radio goes deaf and several clicks of ptt or mox will restore the receive signals. It sounds and acts like the antenna does not switch back to receive. SWR shows perfect and transmit remains good.
  • Dave-N9CHM
    Dave-N9CHM ✭✭
    edited December 2016
    Same here with my 6500, a few clicks with the PTT and the signals come back (happens mainly on 75M, at least for me). It's a known problem, I assume it will be fixed sometime in a future update.
  • NM1W
    NM1W ✭✭
    Tks Ned; I've tried both of those and neither gets it back..
    Tim - W4TME admin
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
