Status for apf slider value - q or level?
Stu Phillips - K6TU
Current release 1.1.3 emits apq_q for the level of the slider but requires apf_level to set using a slice set command.
Is it intended to remove apf_q on the status and emit apf_level instead?
If so, at which release? Trying to sync the iPad app up with 1.1.3!
Stu K6TU
Stu K6TU
A few days ago I changed this so the radio emits "apf_level" instead of apf_q. This should only be on the current development software and not in v1.1.3.
v1.1.3 Should behave as you say, requires apf_level to set and emits apf_q.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
