Status for apf slider value - q or level?
Stu Phillips - K6TU
Stu Phillips - K6TU Member ✭✭
edited February 2017 in SmartSDR API
Current release 1.1.3 emits apq_q for the level of the slider but requires apf_level to set using a slice set command.
Is it intended to remove apf_q on the status and emit apf_level instead?
If so, at which release?  Trying to sync the iPad app up with 1.1.3!
Stu K6TU
  • Ed.G
    Ed.G FlexRadio Employee ✭✭
    A few days ago I changed this so the radio emits "apf_level" instead of apf_q. This should only be on the current development software and not in v1.1.3.
    v1.1.3 Should behave as you say, requires apf_level to set and emits apf_q.
