Is hardware ALC operational with 1.1.2?
edited March 2017 in SmartSDR for Windows
Trying to use an AL80B with a 6700 there is an oscillation/pumping of the RF out when trying to set this up. I've not tried to use it before, but then we all should be wringing out the software/hardware for issues.
Welcome!
  • Member
    edited February 2014
    To my knowledge, it is not yet implemented.
  • Member ✭✭
    edited April 2014
    the release notes for DE1708 are ambiguous then maybe
  • Member ✭✭
    edited April 2014
    The AL80B has more granularity in adjusting than most amps in setup.
  • Member
    I hope that when it is operational, that 6000 series users will use it properly and NOT as a compressor.  The compression should be done on the audio side and the ALC used only as a "woops,I turned my rig up too hot" catcher.
  • Member ✭✭
    edited April 2014
    Yes for sure. I was just trying the options and will never use ALC on an ongoing basis anyways. My AL80B never goes above 500-600 watts max (LP-100A wattmeter or PowerMaster in peak mode).
  • Administrator, FlexRadio Employee admin
    edited March 2017
    This defect has been previously reported and in in the developer's bug tracker for further investigation.
