Is hardware ALC operational with 1.1.2?
K4EAR
Trying to use an AL80B with a 6700 there is an oscillation/pumping of the RF out when trying to set this up. I've not tried to use it before, but then we all should be wringing out the software/hardware for issues.
To my knowledge, it is not yet implemented.0
the release notes for DE1708 are ambiguous then maybe
The AL80B has more granularity in adjusting than most amps in setup.0
I hope that when it is operational, that 6000 series users will use it properly and NOT as a compressor. The compression should be done on the audio side and the ALC used only as a "woops,I turned my rig up too hot" catcher.0
Yes for sure. I was just trying the options and will never use ALC on an ongoing basis anyways. My AL80B never goes above 500-600 watts max (LP-100A wattmeter or PowerMaster in peak mode).0
This defect has been previously reported and in in the developer's bug tracker for further investigation.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 747 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
