under the General Tab , when you put your nickname and call in , is there any reasion it will not g
Member ✭✭✭
NICKNAME AND CALL WILL NOT GO INTO THE RADIO
Welcome!
  • Administrator, FlexRadio Employee admin
    edited June 2020
    Did you click the button beside the text field?
  • Member ✭✭
    edited March 2017
    I was confused too - I was trying to configure it before I connected to the radio, but that wouldn't work.  I had to go back to the settings page *after* I was connected to the radio in smartsdr for it to save and show up on the display.
  • Member ✭✭✭
    edited December 2016
    thanks Jim it's working
  • Member ✭✭
    edited January 2015
    Were is this text field not showing on setup ... using v1.1.2
    Picture please. (Snipping)
  • Member ✭✭✭
    edited June 2020
    Yes, you actually have to connect to the radio before it sends any commands to it.
    But mine wouldn't show anything until I realized that the nickname I was using was one character too long.  Then it wouldn't show anything.  I shortened the name to "Big Kahuna" and it works.  [grin]  My Call and name also works, but my name is short...
    NM9P-Ken
  • Member ✭✭
    edited January 2015
    Problem solved!
    You toggle the Radio Identification to any of the three ..
    Nickname, Callsign  and the Model.
