FLEX 6500 Initial startup
W4EY
Often, I shut down my FLEX 6500 during the late night hours and when away from home for days. When I Power ON the FLEX, I have noticed that after the Power ON Calibration completes and FLEX-6500 is shown on the front panel, the unit is not shown or missing in the CAT Setup panel . After the FLEX-6500 LED is shown on the front panel, around a minute passes, there will be another CLICK sound (Possible Relay) from the FLEX. After this delayed Click is noticed, the Unit is displayed on the CAT display and can be connected.
Is this a problem with my FLEX or just Normal initial startup with the latest SmartSDR?
Mine does this too. I just wait it out. About 45 sec. to "FLEX-6500" display,
then a short double click in another 5-10 seconds. After about 80 seconds
total time, the final click. I assume this is normal. All seems ready to go
after the sequence concludes. This is with my computer already on and
with SmartCat and DAX ready to go.
Being aware of this, I don't initialize SmartSDR until after the last click.
I didn't notice what version 1.0.24 did. I had been leaving it on.
Ned - This is normal, as in there is nothing wrong with your radio but we are looking into syncing the availability of the radio in the chooser and the display of the radio model.0
Right, Tim. This is not an issue for me. I just wanted to share what I found with others
to assure them that this was what "normally" happened.
Thanks for reinforcing the information.
Ned, K1NJ
This has been reported as much better with v1.1.2. We did make a change is some of the startup tasks to make it faster and this could be the reason.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
