getting a dax stream to reliably xmit is frustrating
NM1W
I've had this issue all thru the 1.1 release; I use jt65/jt9 in split mode; I set audio stream 1 for rcv and start each day trying audio stream 2 thru 8 to see which one wants to xmit when I press the tune button in jt65. I always get the ptt to put the radio into xmit mode, but I dont always see power out my external antenna tuner.
Sometimes I'll see that the audio stream is set to xmit but shows nothing on the dax tx meter; Sometimes it shows that there is audio on the meter but still no power out shows on my antenna tuner meter.
I can almost always find a dax channel to xmit on, its just frustrating to find what combo is gonna work this morning.. worse than whack a mole...
I do verify that the dax control panel has the stream selected and set for xmit; that in power sdr the dax button is highlighted, that the rcv slices are the correct mode and size, and that jt65 is configured correctly...
I've yet to find a reliable combination of rig reboots, smart sdr restarts, and pc reboots to fix this..
I'm running win7x64, 16GB ram, i7;
2
We have found an issue like this where more than one PC has the DAX software loaded. We have corrected this issue and will be providing corrected software soon. Is it possible that you have more than one PC on the LAN with DAX? Again, this is a very acceptable thing to do in general.0
Hi Steve,
No I only have smartsdr1.1 on my desktop...
I've seen the comments from others ending up running multiple copies of DAX and I've checked to be sure I only have one; I will say that my normal startup is to boot the 6700, start smartsdr, see the radio is hard of hearing; shutdown smartsdr, reboot the 6700, start smartsdr and then it hears fine... Then I check for a working xmit stream.
If there is something I can do to facilitate debugging it for you I'm glad to help.0 -
Not sure if this is relevant: but this morning when I powered up the rig could hear fine and the dax streams I used yesterday worked fine; Just had to press the dax button on the xmit panel.. Now what is slightly different than normal days is last night when I did a rig shutdown I left the pwr on for another 30 min; Usually when the 6700 appears to have turned itself off I turn off the supply right away... (Probalby getting the power has disappeared msg on the 6700 which I've gotten so I dont notice)0
Worked a couple stations on jt65/jt9 and noise floor jumped up to -80 (from -112); rcvr now is hard of hearing, restart smartsdr, still at -80; Reboot 6700 now at -112.. In smartsdr the dax channels have been forgotten, set them back and continue working new stations...0
- 338 Community Topics
- 579 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
