NF raises when TX
Greg
When transmitting on 10M this evening trying to work FT5ZM the entire NF jumps from about -128 dB up to -70 while transmitting with multiple vertical lines throughout the display.
With the preamp on you are overloading the receiver. You can either:
1. Turn off the preamp
2. Listen using a different antenna (RX/TX on different antennas for isolation)
3. Just understand that the signal will overload the receiver when in transmit with the preamp on
Steve0 -
Thanks Steve. Preamp is pretty necessary on 10M otherwise its pretty deaf here. And I need the gain for DX from my 10M yagi so the one antenna is needed on both TX/RX. Is the overload and danger to the receiver?
Since what we see on the panadapter is not really an accurate picture of that is being transmitted I wish there was a way to switch that off alltogether or to add x amount of attenuation to the receiver during transmit. I had an ANAN for a couple weeks waiting for the flex to get here and that is one of the things they had in their software that seemed to work reasonably well.
Tnx
Greg
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
