Amp keying
Greg
After experimenting with skimmer interfaces all day I decided to try and work KC4AAA on 15m. My external watt meter showed 35W instead of 800W. I checked everything and there were no setup issues. The tx1 is not keying the amp. I also noticed a bit low output with the rig set to 100w I got 80w output. 20% low show a problem some where. Any suggestions? Should I reset the database again? Thanks Greg
Anyone have any input on this? I would really like to be able to use my amp again.
I did a database reset and still not keying the amp.
Well....I guess not. But now its working...just out of the blue....Did not touch or change anything. Wonder if I have a bad RCA cable that just started to show up after the update.
Greg,
Make sure you have it the TX1 Enabled in the Transmit tab of Radio Setup. Have you tried the other TX keying outputs?0 -
Its working now Dudley....no rhyme or reason.....
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
