Amp keying
Greg
Greg Member ✭✭
edited March 2018 in SmartSDR for Windows
After experimenting with skimmer interfaces all day I decided to try and work KC4AAA on 15m. My external watt meter showed 35W instead of 800W. I checked everything and there were no setup issues. The tx1 is not keying the amp. I also noticed a bit low output with the rig set to 100w I got 80w output. 20% low show a problem some where. Any suggestions? Should I reset the database again? Thanks Greg
  • Greg
    Greg Member ✭✭
    edited February 2014
    Anyone have any input on this?  I would really like to be able to use my amp again.
    I did a database reset and still not keying the amp.
  • Greg
    Greg Member ✭✭
    Well....I guess not.  But now its working...just out of the blue....Did not touch or change anything.  Wonder if I have a bad RCA cable that just started to show up after the update.
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    Greg,
    Make sure you have it the TX1 Enabled in the Transmit tab of Radio Setup.   Have you tried the other TX keying outputs?
  • Greg
    Greg Member ✭✭
    Its working now Dudley....no rhyme or reason.....
