Using other ANTENNA on Slice B...D
iz7auh
I need information about a opportunity to use ANT2 for other Slice, I see when I coose antenna 2 on other slice change also on slice A why?
Fracesco,
If you have a 6500 then all slices are serviced by one ADC and therefore use the same antenna. If you have a 6700 then there are two ADC's which can be assigned to different antannas and therefore slices can have different antannas
AL, K0VM
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
