Using other ANTENNA on Slice B...D
iz7auh
iz7auh Member ✭✭✭
edited November 2017 in SmartSDR for Windows
I need information about a opportunity to use ANT2 for other Slice, I see when I coose antenna 2 on other slice change also on slice A why?
  • Al K0VM
    Al K0VM Member ✭✭✭
    Fracesco,
       If you have a 6500 then all slices are serviced by one ADC and therefore use the same antenna.  If you have a 6700 then there are two ADC's which can be assigned to different antannas and therefore slices can have different antannas
    AL, K0VM
