Power slider...F6700
K1UO Larry
Member ✭✭✭
Running V1.1 and notice that adjusting the power slider control is causing a scratchiness sound in the F6700 connected speakers. Nothing big... just reporting it.
Larry, I've never since this in the dozens of versions that I've tested nor have I ever seen this reported. I'm not saying it's not a problem for you just offering couple of data points. I suppose you've tried rebooting your computer and removing power from the radio. If this doesn't work then I suggest you reset the radio to factory defaults. Otherwise, Tim may have a suggestion. Mack W4AX Alpha Tester0
Don't change the power control? :-)
Are you changing the power level while transmitting?
Hi Mac, Ill try as you suggest.. Im just trying to get too many computers upgraded and operational with this new Firmware... so it may well be just needing a reboot. I had not noticed it before this.0
Hi Tim, I do believe I was changing the level while transmitting. Trying to compare the power with the LP100a wattmeter readings. The only TX ant 1 connection I have is the Alpha Dummy Load so at least I had that connected :-)
I would expect a short pop under those conditions. The audio has to stop momentarily when you make changes to the hardware (PA drive level). It isn't a problem.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
