Power slider...F6700
K1UO Larry
K1UO Larry Member ✭✭✭
Running V1.1 and notice that adjusting the power slider control is causing a scratchiness sound in the F6700 connected speakers.  Nothing big... just reporting it.
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Larry, I've never since this in the dozens of versions that I've tested nor have I ever seen this reported. I'm not saying it's not a problem for you just offering couple of data points. I suppose you've tried rebooting your computer and removing power from the radio. If this doesn't work then I suggest you reset the radio to factory defaults. Otherwise, Tim may have a suggestion. Mack W4AX Alpha Tester
    edited December 2017
    Don't change the power control? :-)
    Are you changing the power level while transmitting?
  • K1UO Larry
    Hi Mac,  Ill try as you suggest..  Im just trying to get too many computers upgraded and operational with this new Firmware...  so it may well be just needing a reboot.  I had not noticed it before this.
  • K1UO Larry
    edited December 2016
    Hi Tim,  I do believe I was changing the level while transmitting. Trying to compare the power with the LP100a wattmeter readings.   The only TX ant 1 connection I have is the Alpha Dummy Load so at least I had that connected :-)
    I would expect a short pop under those conditions.  The audio has to stop momentarily when you make changes to the hardware (PA drive level).  It isn't a problem.
