CW keying output
DonS
Member ✭✭✭
That is normal. The pip on the screen is a visual indication of your transmit frequency. If break-in is disabled, you will not transmit when you press the key. If you hit MOX or mash the footswitch, the key will send RF. Why anyone would use this on purpose instead of break-in, I don't know, unless they hae some large relays on old amps or mast-mounted preamps that they need to sequence properly and not wear out with rapid keying... I have occasionally found the "function" you discovered to be helpful in spotting my transmit frequency. And I have been fooled a few times when using headphones and full break-in, thinking I was transmitting when I had not set my slice to TX! The "pip" was dancing and I couldn't understand why that S-9 signal wouldn't answer me!1
Interesting. My 6500 doesn't do that.0
My 6300 doesn't do that either
When I turn off breakin I noticed that the radio does not transmit. The light above the power switch does not turn red until I turn Breakin back on.0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
