MMTTY Soundcard. DAX Audio select
EMIL-DL8JJ
Hello guys, how can i select the DAX Audio RX1 (DAX RX Audio) on MMTTY Setup SoundCard / Reception. On Setup they are only 16 chooses, but not DAX Audio RX1. On FLDIGI workt all well. How can i change the list and choose other one, with is not in the list? Dax created 40 of them. Thanks Emil, de DL8JJ Flex-6700
Go into the Windows audio control panel and disable some of the devices that you dont need to use = such as the reserved devices created by DAX. Restart the computer and now MMTTY will only enumerate the devices that are enabled. I did this to resolve the same issue for myself. Stu K6TU PS: right now, this is the only solution I am aware of...0
Hey Stu Thanks. It dos not workt. If i disable some of them, (Win 8) MTTY steel take sme of them and not realise, that i disabled some of them. If i uninstall, after reboot, the Dax put all again. For sure, MMTTY need update for the new SSDR. cu Emil, de DL8JJ il, de DL8JJ0
Emil, I should think Stu's solution should work... However; I run two versions of MMTTY, 1Stand Alone and the 2nd is the TTY Engine attached to Writelog... MMTTY Ver1.66G MMTTY Ver1.68A Both Versions show 16 DAX Drivers in both Reception and Transmission Collumns.... I may just be lucky but they both Show DAX Audio RX1 and TX1 for selection. Works Great... Check to see if you have an OLDER VERSION and a more current download would fix your problem... Ken, W9IE0
- 390 Community Topics
- 661 The Flea Market
- 54 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
