How accurate is the vertical, signal strength scale on the F6.7K?
K2CM
I wish to use my F6.7K as an instrument to measure isolation in a home brew antenna switch.
It is VERY accurate at its resolution. Calibration is done at the factory. I've confirmed my signal strength scale with a NIST calibrated source. Mack W4AX Alpha Tester0
There is a bug in the vertical scalling of the panadapter that could make results inconsistant. A more accurate reading can be had by turing the RX slice to the signal of interest and then mouse over the s-meter to get a signal level in dbm. If you doing a wide band comaprison, then you may wish to get into the 'WIDE' ( no band pass filter ) mode. AL, K0VM0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 864 Genius Products
- 306 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
