How accurate is the vertical, signal strength scale on the F6.7K?
K2CM
K2CM Member ✭✭
edited March 2019 in SmartSDR for Windows
I wish to use my F6.7K as an instrument to measure isolation in a home brew antenna switch.
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    It is VERY accurate at its resolution. Calibration is done at the factory. I've confirmed my signal strength scale with a NIST calibrated source. Mack W4AX Alpha Tester
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    There is a bug in the vertical scalling of the panadapter that could make results inconsistant. A more accurate reading can be had by turing the RX slice to the signal of interest and then mouse over the s-meter to get a signal level in dbm. If you doing a wide band comaprison, then you may wish to get into the 'WIDE' ( no band pass filter ) mode. AL, K0VM
