Very low output power on bands ffrom 20m to 10m
H L
I picked up a used flex 1500. Figure before buy new and bigger I might as well start small, and it was a low price. In any case in the process of learning how it works I hooked it my my dummy-load power meter. That was when I discovered I had a problem 160m-30m I am running from 3.5 watts to 5 watts. From 20 meters to 10 meters 1.25 watts to .75 watts. 6 meters 5 watts. The list of what I have done it too long but I have tried everything to get 5 watts on all bands. Also note for about 5 min I DID get 5 watts on all bands. At that time I had the case off and the boards out. My fear/concern is a cracked PCB, or a cold solder joint. Just curious to know if anyone has had this problem? Also what is common wih 160 to 30 meter and 20 meters to 10 meters as far as say a relay.or other device that might have a bad joint Harry.... harrylatterman@yahoo.com
As a long fan of Flex radios... This is the first time in approximately10 years being a Flexer that anyone has ever mentioned a cracked PC board! Unless the previous owner cracked it... Do you think that may be the reason you got such a fantastic DEAL?0
Thinking about what I saw yesterday I will have to agree the quality of the PCB is excellent. However not the last owner, but one of the previous owners **** up the BNC and broke it off the board. He then did a **** poor job of gluing it back and trying to solder a ground strap across it. I cleaned that up last night. Figured if he did that maybe other damage was done. Since for a few minutes I had full power on ALL bands doing the TUNE and it went away when I put it all back in the box then something like a cracked board or cold solder joint might be the cause....I am heavily leaning toward a cold solder joint based on having to find and fix SMD boards in the past. Time to get a webcam out and do some serious looking. The person I got it from I do believe he was unaware of the problem. You can not tell from looking at the PowerSDR display since it does not show real power out, but where you set the drive. No real SWR I found out. So if he always saw 100% why doubt it. People make contacts with peanut power every day. Besides he used it mostly on 160 and 6 meters 160 is putting out almost 4 watts and 6 meters 5 watts. I do believe from the half a dozen emails we have shared that he was clueless to this problem He used the radio for a lot of SWL it appeared. He love the pan adpator so much he went out and got a Excaliber SDR RX. In any case I emaile Flexsytems tech support last night also. Waiting for response. Might set up a webcam and get a **** of coffee and so some looking at each and every solder joint. As I said I have had to do this before. Thank your for your time writing back. 73 Harry k7zov0
Some time a good buy may be not. Dudley and the group at FRS will treat you well and get that problem resolved. It appear that the damage was caused by the previous owner. I had a F1.5K that I used in my car and the garage; that radio was indestructible.0
Harry - I see you have a HelpDesk ticket on this issue so I am going to close this Community topic.0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
