Kick **** radio - on a RTTY Contest !
James Kennedy-WU5E
Member ✭✭✭
FLEX- thanks for making a kick **** radio- In the ARRL RTTY Round Up I gave the FLEX 6500 12 hard hours of contest with no break CQ's 1,290 contacts 215 Points 11,395. DAX worked great! no issues at all thanks again FLEX
JIm What software were you using? fldigi, mmty, hrd? If you used filtering, did you have issues with centering the signal in the filter passband. It would seem to me without point and click getting the signal centered would be a pain.0
no I'm using FLDIGI version 3.21.77 Jim wu5e0
all I used was 20m USB and 40m LSB and a little bit working DX on 15m no fliters used at all, I live in the country and have no noise! Jim wu5e0
I have found it easy to use the narrowest of manually defined filters and tune one of three ways
1. point n click on mark (quickest/easiest of the three since v1.5 )
2. flex knob till rtty signal just fits into filter and fine tune w/ mouse wheel if need be. With a very narrow filter, you get an idea where the sweet spot is w/o having to fine tune with the mouse wheel and the v1.5 rtty tuning lines on pan adapter make that more intuitive.
3. click n drag pan adapter till rtty signal just fits w/in filter and fine tune w/ mouse wheel if need be.
Although I have not had the opportunity to play with 1.5 much during rtty tests due to work schedule, I would imagine running a frequency would easy as well by simply having receive split open and point n click on mark for multiple replies that may be slightly off your transmit frequency. Not certain about that, but it should be doable in theory. I know you can do the same with fldigi by locking the xmit freq within the fldigi program.0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
