DAX
Bob G   W1GLV
Bob G W1GLV Member ✭✭
edited February 2019 in SmartSDR for Windows
Does DAX signal go thru the PC sound card. Or is that processing done in the radio.
  • George KF2T
    George KF2T Member ✭✭✭
    AFAIK, neither. DAX takes the selected passband from the radio server and routes it to a virtual sound card, if you will, in the PC for conversion & delivery.
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    Bob, DAX signals do not 'go thru' the PC system sound card. However each DAX endpoint acts nearly exactly like a PC sound device.. They all appear in the window 'Audio device manager' and have nearly the same controls as a standrad PC sound card. Installing DAX may mean that the default system sound device needs to be reassigned to the PC hardware sound card. AL, K0VM
  • Tim - W4TME
    edited December 2016
    You are correct.
