Connecting an Expert 1K Linear Amp?
Did you try before you ask a search here with key "Expert 1k" ?1
Hi Kevin, you need DDUtil V3 which you have to connect via the SmartSDR CAT 1.I have connected the Expert 1K via the RS232 connection of my PC to the S232 Input of the Epert. There you have to select this port in the setting menue under SET>CAT>SPE RS232 . 2. In the DDutil V3. Setup select Enable SPE 1K-FA and com 1 I can send you by email my screenshots if you have still problems. Tha will be the easiest way to lean how to configure SmartSDR CAT DDUtil ec vy73 Norbert email: dj7jc@t-online.de www.dj7jc.de1
Hi Kevin, all is running fine with me. If you want I can send an email with my screen shots with installation setups. Vy 73 Norbert dj7jc@t-online.de www.dj7jc.de0
Hi Kevin, I am successfully using 2K-FA with 2 USB connections - one is standard for Expert apps second is handmade via DDutil, all works fine. In DDutil utilized Passive Listener port for Amp driving0
Hello Kevin, My setup is very similar to Norbert's setup. DDUtil v3.0 works great. RS232c from the Expert 1K-FA is connected through an adapter to a USB port on my PC. ALC is not used. Has worked flawlessly with my Flex-5000 and now my Flex-6700. Rich - K3SOM0
sorry its been a while guys i've been away with work, many thanks for your comments, i'll give it a go! Kev
Sergey... I got a 2K-FA this weekend... How did you EXACTLY hook it up to the 6700
Specifically I am interested in the wiring diagram for the DDUTIL Passive Listener Port for Amp Driving....
Hi. I need the hookup schematic for the spe 1k cat and flex 6300.0
Hi Ron,
please send me your private email address,
73 Norbert
DJ7JC@t-online.de
KY6LA wrote a nice write up for his Expert 2k that actually works nicely with the 1k.
From KY6LA post (based on Sergey RA3AJK original idea)
Making the cable
1. Cut the male end off the 9 Pin cable
2. Identified the wires to pin outs on DB9
3. Connections are as follows:
DB- 9 F <--------------------------------> DB-15M
Pin 2 RX232 <-------------------------- Pin 9 TX 232
Pin 3 TX 232 -------------------------> Pin 1 RX232
Pin 5 GND <---------------------------> Pin 4 GND
On the Computer
1. Connected cable to computer COM5 - (you can use any spare COM Port or a USB to Serial device)
2. Set COM5 to Passive Listener in DDUTIL
3. Set Baud rate to "9600-N-8" in DDUTIL
4. Enable DDUTIL "Passive Listener"
5. Enabled DDUTIL "Follow PDSR"
6. Enable DDUTIL "Follow Mode"
On the 2K-FA
1. Set CAT to "Kenwood"
2. Set Baud Rate to "9600"
Now the 2K-FA automatically follows the 6700
NO NEED TO HIT PTT
My comments:
Make sure to select RS232 as the CAT mode inside the Expert 1K-FA CAT menu. When I selected Kenwood it didn't work.
On the 1K-FA
1. Set CAT to "RS232"
I actually use 2 USB to Serial adapters. One to control the Expert 1k remotely (with DDUtil) and another one to send Band Data to the amp. This last one is the passive Listener.
I made my own cable with a cheap eBay USB-to-Serial board with the USB plug and my own DB15 connector.0 -
Please if you can send to me too, please. Giuliomarcato@gmail.com0
I have the 1KFA as well. DDutil works fine for following bands but I have never got the auto drive to work. What output should the Flex be set to in the Radio Setup > Transmit Plan? Can any advise how to debug this...ie what to check.
Mike, W8MLS
Howard,
Thanks for the info... Passive Listener does work. What does not work is auto drive. I have the Passive Listener on com 8 (serial cat) and set to follow the radio. Protocol is Kenwood. In the Amp section I have the 1K selected and set to com 10 (usb input on spe). the rf power on the flex does not match what I have in the auto drive section.
Update - I did some testing. I found out that if I disable the SPE on the Amps section then auto drive does work. I see the correct rf output setting for the bands. However, I see no way to turn the spe on/off or control the spe (input).
Mike0 -
Hope this screenshot helps. Remember to,enable both STBY
Howard, thanks for the screen snapshot. I did figure it out. I had every thing set correctly 1st time. I think my config file was corrupted. When I disabled and re enabled the spe in the Amps section it started to work.
73, Mike W8MLS
This is slightly off topic, but this entire thread reminds me of the main reason I have decided to wait for the Power Genius XL. It will work 100% seamlessly with the 6700, with a simple Ethernet connection. ALC, band change data, health and status info, etc. All fully integrated with the 6700, plug and play ultimate simple. The neatest thing will be how it will work seamlessly with WAN and Maestro! 73, Larry WA7LZO0
Could you please send me the screen shots of hooking up the 1,3 FA with flex also.
73 Stan W8ATE
Stan@laseritup.com
Hi Guy's
Has anyone done a videio and put it on YouTube or uploaded it to a wedsite showing you how to set everything up with a Flex Radio to the SPE Expert 1K ??? the whole process regarding what leads you need also what software and the settings??
Regards
Rob
OM Rob,
You need a quality USB to RS 232 dongle plugged to the back of series 6000 radio and to RS232 socket of
1 kFA. Also a usual key line is needed. I assume you use a series 6000 radio. In SSDR go to SETTINGS and look at USB Cables and set up connection with the amplifier. Make relevant settings in 1 kFA menu, study both manuals first. Also program antenna inputs and outputs. In 1kFA preset drive power in the order of 20-30W or less for testing. This setup is very stable, no need to worry about overdriving PA .
Tom
Hi Mr Radio
Thanks for the reply ok I'm using a flex 6300 and from the rear view I would use a usb to serial cable 9 pin and that would connect to the Expert 1k RS232 socket and then from the back of the flex 6300 PTT which will go to the Expert 1K Relay RCA IN1 and just do the setting on the Expert 1K and also do the settings in the SSDR software for the PTT keying ?? I think thats the way you are saying I should do and everything will be working.
Regards
Rob
- 314 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 242 SmartSDR CAT
- 174 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 118 FLEX-8000 Signature Series
- 855 Maestro
- 44 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 408 Remote Operation (SmartLink)
- 132 Contesting
- 695 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 920 Third-Party Software
