MAC address
Greg
Where can I find the MAC address for the radio? I want to reserve its IP in my router settings. Tnx Greg
Take note of the IP address of the radio on the Connect window or in the SmartCAT software. Then on your windows box, open a command prompt and type "arp -a". Find the IP address of the radio in the list , and the MAC address is right next to it.0
You can also look in your router's DHCP table. The Flex MAC starts with 50:56.1
Great. Thanks!0
That would likely work for most people, but I actually have multiple devices on my home network that have a Texas Instrument NIC. http://www.coffer.com/mac_find/?string=50:560
My 6700 starts with 84-7e0
That's TI also, which is why you can't assume it's always 50:56. My method or checking your DHCP lease table in your router will always provide you the correct MAC. http://www.coffer.com/mac_find/?string=84:7E0
That's where I found it. Tnx!0
Start SmartSDR and connect to the radio. Once you know the IP address of the radio from the Radio Setup form, open a command window and do an "arp -a" to get the MAC address.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
