No PTT hint
Roger Rockwell/na4rr
Until today I've been running 6700 direct connected to desk computer. With Beta I decided it was time to use the laptop and connect v Wifi. I got through the initial setup all ok. So now time to make use of DAX and run fldigi. Receive was just fine and all was right with the world but could not get PTT v fldigi. Tried every combo of configuration under Hardware Ptt and RigCat configuration. Long story short. After 6 hours. I opened Device Manager and show hidden devices. There grayed out was an additional com port 4 and 5. (The ones I had been trying to use.) I deleted those and now I have the 6700 running fldigi on the lap. So the hint: if no ptt, look for something else that my be stealing your port from you. It seems to me that you should get a "can't open port msg" but you don't. 73 Roger na4rr
Roger, Could you check the latest CAT log file for me? Users[your user name]AppDataRoamingFlexRadio SystemsSmartSDRCatLogs There may be up to five files (this is a rolling log system) but I am interested in CatLog.txt. See if there is an error logged "Access to port COMnn denied". If so, would you send me a copy of the file: k5kdn@flex-radio.com Thanks, BobT0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
