No PTT hint
Roger Rockwell/na4rr
Until today I've been running 6700 direct connected to desk computer. With Beta I decided it was time to use the laptop and connect v Wifi. I got through the initial setup all ok. So now time to make use of DAX and run fldigi. Receive was just fine and all was right with the world but could not get PTT v fldigi. Tried every combo of configuration under Hardware Ptt and RigCat configuration. Long story short. After 6 hours. I opened Device Manager and show hidden devices. There grayed out was an additional com port 4 and 5. (The ones I had been trying to use.) I deleted those and now I have the 6700 running fldigi on the lap. So the hint: if no ptt, look for something else that my be stealing your port from you. It seems to me that you should get a "can't open port msg" but you don't. 73 Roger na4rr
Roger, Could you check the latest CAT log file for me? Users[your user name]AppDataRoamingFlexRadio SystemsSmartSDRCatLogs There may be up to five files (this is a rolling log system) but I am interested in CatLog.txt. See if there is an error logged "Access to port COMnn denied". If so, would you send me a copy of the file: k5kdn@flex-radio.com Thanks, BobT0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
