DAX Tx audio does not key VOX
WA6FXT Mike
Mike, VOX is not implemented with DAX. You should be able to adjust the slider in the VOX control panel to get as much signal as you need. Mack W4AX Alpha Tester1
OK! Not implemented... No problem, just another item missing from the Release Notes.0
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
