DAX Tx audio does not key VOX
WA6FXT Mike
WA6FXT Mike Member ✭✭
edited March 2019 in DAX
Is this expected? DAX Rx works great; though, the audio is a bit low.
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Mike, VOX is not implemented with DAX. You should be able to adjust the slider in the VOX control panel to get as much signal as you need. Mack W4AX Alpha Tester
  • WA6FXT Mike
    edited June 2017
    OK! Not implemented... No problem, just another item missing from the Release Notes.
