DAX Suggestion
edited January 2020 in New Ideas
Currently I use digital and voice modes to pass traffic on nets the fact I need to switch back and forth between DAX and BAL to use both modes of operation make it very inefficient to operate. Could a future change be considered to make DAX work without having to make that change. I am sure this would also be helpful to people that use voice keyer software on there computers as well.
0 votes
In Review · Last Updated
Welcome!
  • Community Manager admin
    edited February 2017
    Select USB instead of DIGU (or LSB instead of DIGL). Then Select the BAL input. Then select the DAX input. Now if you PTT from CAT, you can use DAX audio and if you PTT from the front panel or foot switch (RCA) it will use the BAL audio input.
  • Member ✭✭
    edited December 2013
    Thanks for pointing that out. One last question any way to hear the DAX audio in the monitor?
    edited June 2017
    I assume you mean transmit monitor. This is on our to-do list -- to enable the MON button for DAX TX audio.
  • Member ✭✭
    Thanks for the Great Job you guys are doing.
  • Member ✭✭
    edited October 2019
    Travis, You may listen to the Audio in DAX through a windows setting. Get here through the control panel / sound or right clicking on the speaker icon in the system tray and choose recording devices..
  • Member ✭✭
    edited December 2014
    Travis, Thanks for the tip
  • Member ✭✭
    edited December 2016
    OK.... thats goos news and not me stuffing up as usual.
  • Member ✭✭
    edited January 2015
    Thanks Robert
  • Member ✭✭✭
    edited January 2020
    Tried but didn't work for me. I was getting what appeared to be thumping sounds. I will need to monitor my signal on another rx to see if that is appearing on the output.
  • Member ✭✭
    Thats a good workaround too Robert.... looks like I wasn't the only one sniffing for an answer.
