Monitoring on DAX ?
James Nelson
Can we monitor the DAX input ie; hear FLdigi modes going to air on tx ? I notice the monitor "MON" button that operates on voice mic in doesn't seem to path DAX in to the speakers or phones in DAX mode. Apologies if I have missed something in the release notes or docos...
I believe that has been added to the to-do list. Meantime you can use the USB mode instead, Monitor works there.0
Hi, I thunk you can listen the DAX channel you are using on TX enabling it in Windows Audio panel: "listen this device". 73 Beppe ik3vig0
So, Dudley, is there nothing "special" about the DIGIU & GIGIL buttons except that it stores the parameters for digital, and turns compression & EQ off? That is good to know if true.0
MON is not available with DAX at this time. In addition to turning off the un-needed and potentiality signal distorting DSP when in DIGx mode, it also does a "quick setup" of the DAX channel and changes the audio input to DAX for you, reducing the number of changes to have to make to operate an ASFK mode.0
Tim,
Should I be able to monitor RTTY LSB Audio YET ???
or is this still on the TO DO List....
Ken W9IE0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
