DAX devices
Greg
Greg Member ✭✭
edited March 2019 in SmartSDR for Windows
I am trying to use DAX with DXLabs WinWarbler. But when I go to WW it does not show DAX Audio RX1. See attached. I can select channel 3 which does show but why would it not show channels 1 or 2? Tnx Greg
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Greg, WW only list the first 16 audio channels it finds. This is a limitation of WW. Perhaps if you contact Dave, the author, he will increase the number of channels. One work around is to disable DAX channels you're not using via the Windows Mixer control panel. This is not an issue with SmartSDR. I simply use DAX RX/TX Channel 3 without issue. 73, Mack W4AX Alpha Tester
  • Greg
    Greg Member ✭✭
    edited December 2013
    Thanks Mack. I figured as much and already sent an email to the DXL reflector. I had to use pair 4 to find something to match up. :) Its working very well so far. Tnx again. Greg
