DAX devices
Greg
Greg, WW only list the first 16 audio channels it finds. This is a limitation of WW. Perhaps if you contact Dave, the author, he will increase the number of channels. One work around is to disable DAX channels you're not using via the Windows Mixer control panel. This is not an issue with SmartSDR. I simply use DAX RX/TX Channel 3 without issue. 73, Mack W4AX Alpha Tester1
Thanks Mack. I figured as much and already sent an email to the DXL reflector. I had to use pair 4 to find something to match up.
Its working very well so far. Tnx again. Greg 1
- 696 The Flea Market
- 121 Aurora
