Will SmartSDR running DAX automatically adjust frequency for digital mode offset?
When DAX is enabled, and we can operate PSK and RTTY, will SmartSDR automatically compensate the frequency offset so that software utilizing cluster spots will automagically place our signals with the correct offset. Or in other words, until FSK comes out will we still have to employ an offset like we do with PSDR so that when WE transmit a cluster message, it will be correct for others receiving our cluster DX Spot?. AND When we use our contest or logging software to jump on a cluster spot, we will be on the correct frequency? If I understand DAX correctly, we will still be operating afsk when running rtty????
2
I agree that a click-tune offset & a CAT command VFO offset like we have in PowerSDR are essential. -- 73, Ray, K9DUR0
Bill - just to be clear, DAX is not digital mode operation, although it most likely will be used in conjunction with DIGU and DIGL. DAX is Digital Audio eXchange which is a method of receiving and sending slice audio and IQ data in a binary format between your 6000 and a Windows sound card device. This is to facilitate operating ASFK modes without using the ACC connector or other analog audio interface. What you are describing is the behavior of DIGU and DIGL interfacing with CAT. That is a completely different feature and is not associated with the current DAX development effort. It will most probably be addressed before the 1.4 release.1
I missphrased that Tim, I'm aware that DAX is like a digital soundcard But my question still holds, as I 'THINK' it will still be afsk rtty and of course PSK, JT etc. are all soundcard based. Consequently, I think (which is where I get into trouble) that for RTTY, a automagic offset will be needed?0
Oh and one more issue, the offset is mostly for RTTY. I am thinking that psk, jt AND all the other alphabet audio modes don't need the offset?????0
All ASFK digital mode will need an offset because they do not operate at 0 Hz (the slice carrier line frequency).0
Pse do the math for me. But I think the offset is the same for all the non FSK digital modes??0
The offset is where you like to operate. Example, in Fldigi it is set at 1000 Hz. I like 1500 Hz so I change the "sweet spot" so that my offset is 1500 Hz when I use the QSY function wich takes any signal on the waterfall where I have a decoder and changes the slice frequency so that the decoder is at a 1500 Hz offset. ASFK RTTY has a standardized convention for the LSB offset.1
Thanks, yes I use 2125 for rtty, and lately I'm playing with JT which is really sweet system with Flex. Still a bit shy of DXCC using JT. Thanks for the education. But stay close, you may have to re-educate me when SmartSDR is able to do digital. :-)0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
