NOISE BLANKER
Larry Davis
hello just got 6700 few weeks ago i think the nb isnot working yet am i right the 5000 got a much better nb let me know about that
All the Dsp functions are working. Click on the nb it will turn blue. Give it a little time to process the noise, if it did not help move the slider to the right, allow to adjust to the noise. If all the way to the right does not help you have a noise which the nb is not designed to help. Then you should go to the NR and use it and the Agc threashold adjust to get the noise to a acceptable level or no noise. I have a terrible electrical noise at times, I can get rid of it with the nb but if I am talking to a strong station with the nb all the way to the right you will degrade the incoming strong signal. I will use the Agc threshold with this stituations and can stop the noise and not degrade the incoming signal but if the incoming signal is in the noise use the nb and the noise will decrease , behold a signal will be heard. It's flex magic! Have a great thanksgiving.0
I've not had as good results with the NB as you, Dave. I've tried the AGC-T route and am still unable to get it to work as consistently well as my old 5K did.1
i got the 5000 still the nb on the 6700 don,t work for me if you can,t hear them you can work them very poor i will turn off till they fix0
This topic has been re-classified as a Problem topic.0
i sent a file from the 5000 to flex hope you guys got it the nb on 5000 takes it out but the 6700 don,t i will be off the air with 6700 till they fix it0
I would like to see a video showing how these functions are intended to work.0
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
