The S-meter for SmartSDR is available.
2»
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    edited December 2016
    Gary, thanks for your info, but I'm still cannot get it to work.
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited July 2016
    downloaded and the result ws 1.5 meters! Like one meter and 1/2 of another all together as one! I am not sure what is going on here?
  • Dale KB5VE
    Dale KB5VE Member ✭✭
    edited April 2014
    I run a 26 inch 1980 monitor and I donot have to increase the resolution to 125% I run 100% . Display is sharp and very readable. You might need to look and see if your tv on graphics card has the over scan option so you can adjust your screen to your monitor. Most newt vs/monitors adjust this auto actually. That will solve you meter problem
  • Charlie, WA3UTC
    Charlie, WA3UTC Member ✭✭
    edited December 2013
    Beppe, great work and the S Meter works well. Thanks so much for providing this to the community. 73's Charlie, WA3UTC
  • Beppe IK3VIG
    Beppe IK3VIG Member
    edited June 2020
    Hi, a new version is available at usual download page. Whats new: new graphics on numbers and backgrounds. 73 Beppe ik3vig woodboxradio.com
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited October 2019
    Beppe, I Like the new features and the dual RX ability of the meter. Ps. On your web page please put a Euro to Dollar conversion to donate PayPal.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    I like it, Beppe. The larger numbers are much easier to read. Thanks a lot!.
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Mille Grazie 73 Chris
  • Albert PA0A
    Albert PA0A Member ✭✭
    edited October 2019
    Beppe, Thanks for providing the new S-meter. In my opinion the red over S9's are a bit oversized at the moment and do not match with the rest of the picture. 73, Albert
  • Dale KB5VE
    edited October 2019
    What is the latest version number. I deleted and went to site to download. I do not see any change. Version I have shows 1.01.
  • Albert PA0A
    edited March 2014
    The latest 1.0.1.0 shows Signature Series, the old WoodBoxRadio.
  • Ernest - W4EG
    edited January 2015
    Download the one that is name "BobSmeter-Flex"
  • Ernest - W4EG
    edited January 2015
    Now that you mentioned it, you are correct. The black line is thinner and it appears as not a continuous solid line. However, for free it's a nice looking meter! Thanks Beppe
  • Ernest - W4EG
    edited January 2020
    Keith Pawley Here is how to get the S meter working; Go to:http://www.woodboxradio.com/flex6000.html Look for the following S meter "BobSmeter-Flex" and download it (remember where you put it or downloaded to the desktop) After downloading it - unzipped the file BobSmeter-Flex_v1 Open SmartCAT and set a pair of com/port i.e, 5-15 Look for BobSmeter file and run it The meter comes up - set the meter port to 5 every thing else should work. Make sure you check for handshake between the meter and SmartSDR CAT. Finally open the folder and look for "BobSmeter executable file and it will show on your desk top.
  • Keith Pawley
    Keith Pawley Member ✭✭
    Thank you very much it is now working kind regards Keith M0PAW
  • Tim - W4TME
    This is a great conversation that's separate from the main topic, so I created a new topic to continue the discussion. Please reference the new topic here: How to get the Woodbox Radio S-Meter working?
  • Was very unhappy to find out that I was unable to download from this site😢 ; Could someone forward to me at W2NDBAE@Gmail.com🌕
  • johnn1jm
    johnn1jm Member ✭✭
    Both links in this thread get a page not found.
    John N1JM
  • Johan SE3X
    Johan SE3X Member ✭✭✭
    edited March 2024
    Howard KY6LA shared the exe file with his Dropbox back in 2018. Seems it's still working:
    https://www.dropbox.com/s/223si9ks962n1av/Smart%20S-meter_V1.6.zip?dl=0
    Cut and paste and you should be fine.
  • N5NHJ
    N5NHJ Member ✭✭✭
    I have the Version 1.0.0.
    I just made it available for download here:
    https://www.dropbox.com/scl/fi/7eorkrva7b9mezgn6q589/Smart_SMeter_PLUS.zip?rlkey=7wwoq65d819a1y597h4n65w6a&dl=0
    It would be great if someone can share the latest version.
  • ka9ees
    ka9ees Member ✭✭✭
    What's the difference between Plus and v16?
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    I think its actually ver 1.6 but the difference is 1.6 can run 4 instances of the meter to use with 4 slices.
  • N5NHJ
    N5NHJ Member ✭✭✭
    v1.6 doesn't show the VFO frequency while PLUS does..
    Plus is the same version I uploaded to Dropbox.
    The release note for both of them shows Rel 1.0.
    Based on the original post from Beppe, there should be a version with a different graphic.
    More info anyone?
  • Trucker
    Trucker Member ✭✭✭✭
    In the Meters Tab there is a selection for two different meter backgrounds. One the classic Kenwood analog meter with the white background and the other with a black background.
  • N5NHJ
    N5NHJ Member ✭✭✭
    Yes, but none of them looks like the one shown in the original posts.
