V1.0.5; Error message when changing BAND without closing RX-A... W/screen capture
k0eoo
Member ✭✭✭
When I first bring up SSDR V1.0.5 and immediately change the band to something other than 20m I get a long error message. This has happened each time I opened SSDR, but only if I don't close RX-A first. If I close RX-A first the band changes normally. In the past I was always able to change bands with RX-A opened; the new band would come up with RX-A opened and ready to go.... I was able to get a screen capture this morning while I was trying to work K9W on 80m.... Dennis, k0eoo
What radio model are you using?0
I had it one time on my 6500.0
OK. We are redoing the band change logic in SmartSDR v1.1 that will resolve this issue. Currently it is done in the client software and we are moving that logic into the radio which should prat this error.0
6500....0
Confirming this issue on 1.0.5 and my 6700 but with RX-B0
Same here 1.05, 6700, two slices open operating split. Change bands and it crashes0
See my comment above. This should be resolved in SmartSDR v1.10
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
