V1.0.5; Error message when changing BAND without closing RX-A... W/screen capture
k0eoo
Member ✭✭✭
When I first bring up SSDR V1.0.5 and immediately change the band to something other than 20m I get a long error message. This has happened each time I opened SSDR, but only if I don't close RX-A first. If I close RX-A first the band changes normally. In the past I was always able to change bands with RX-A opened; the new band would come up with RX-A opened and ready to go.... I was able to get a screen capture this morning while I was trying to work K9W on 80m.... Dennis, k0eoo
What radio model are you using?0
I had it one time on my 6500.0
OK. We are redoing the band change logic in SmartSDR v1.1 that will resolve this issue. Currently it is done in the client software and we are moving that logic into the radio which should prat this error.0
6500....0
Confirming this issue on 1.0.5 and my 6700 but with RX-B0
Same here 1.05, 6700, two slices open operating split. Change bands and it crashes0
See my comment above. This should be resolved in SmartSDR v1.10
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 152 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 866 Genius Products
- 445 Power Genius XL Amplifier
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 717 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 939 Third-Party Software
