compression/ downward expansion audio or rf influence?
K4EAR
I like to use an external mic preamp and rack gear, as the compression/expander function seems too aggressive for my tastes with 1.05. Does any of the onboard processing happen in the RF domain or is it in the audio codec before the IPA/PA? What is the recommended max input for the rear panel jack? I feed -10dbm and the COMP level at 0. It seems the compression/downward expansion fight each other. Maybe in 1.1 we can have more control over this.
It is all in the DSP. The audio input device in the FLEX-6000 series radios is designed for a “consumer line level” specification. This is defined as -10 dBV. If you plan to use “professional line level” (+4 dBu) devices to feed your radio, you will need to reduce the output level so that it does not exceed the -10 dBV level. The hardware input will clip around 0 dBm. I use a mic preamp and it is set for 0 dB on voice peaks. In SmartSDR, the +20 dB boost is turned off and the mic gain is set for 10, which shows 0 dB on voice peaks. Since I am not using an outboard compressor, I have compression on at a setting of 50. The compressor is actually a compander with a downward expander. If you are using very low levels of compression, the action is mostly going to be downward expansion.0
Hello Tim This kind of information is very useful indeed, thank you. I am using the 6700 with an Optimod 9300 Digital audio processor. The two units seem to be working fine together, but I would be grateful for any comments or guidance from you. Kind regards Peter G4BIM0
In the next generation of hardware go to AES/EBU and S/PDIF options for input options :-)0
Agreed.....0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
