transmit filter persistence.
Edward Armstrong-WB2K
have just installed V1.0.5 and in the release notes said that transmit filter persistence was fixed well it is not it does not saving the settings even though it looks like it does in the software. This is an existent problem that Tim said flex was aware of and will be corrected in order for the filter to work properly and for me to get the base back in to my audio I have to go back into the audio settings every time the radio is turned off and then back on and then delete the filters even though by looking at them seem correct but are not and type 30 for low and 3800 for a high and now delete them and then put in my settings which are 50 for the low and 4050 for the hi and everything is okay so persistence is not fixed in this beta and their are three of us who have to do to same. I am a little bit concerned when someone says something is corrected and it is not I feel I should not have to wait for this fix would appreciate if someone would listen on the other end and record the transmission With a flex 5000 or so and played it back when the filters are being manipulated you will see you have a problem saving the transmit filters Settings WB2K
I have tried to find where the transmit filter persistence was "FIXED" and was not able. Can you refer me to the page and line where to find it. However, I did find the following on "SmartSDR for Windows v1.0.5 Release Notes" Date November 1, 2013. On page 4 "Known Issues,Caveats and Limitations." 1. Many settings in the radio are persisted across startup of the radio. Band and Mode oriented controls are not persisted at this time but are planned for a future release. US1956 Did I missed something? Or did I misunderstand what I read?0
Hi Ernest you are right I fail to see the words future releases so I apologize for the mistake. But persistence is very important in any radio especially in this type of radio so if you can please tell me when persistence will be implemented in this radio. Do not know what US1956 means. When I took delivery of this radio transmit bandwidth persistence was implemented but does not work as you know do you not think when a beta was released that possibly an issue like this should have been corrected there are a lot of audio files out there and if we were not able to adjust the transmit filter the radio would not be any good to us appreciate your time WB2K0
Ed - WB2K -- I just did a search and got you some information that will help. I will quote a few that you may want to follow. In the early released of SmartSDR Beta test, we asked the Company to make persistence a priority and they listened to our request. Tim - W4TME "We will be adding basic persistence to SmartSDR in or before version 1.0 and more advanced persistence capabilities will be included in future releases. Alan - K2WS "You may want to read Alan "Adding radio persistence capabilities" that question is analyzed very well , with suggestion for the mean time. Mike - W8MM "The settings are persistently stored in the hardware (NVRAM)."0
This defect still exists in SmartSDR v1.0.5 and we are aware of it. It is on the list to be addressed.0
Hi Ernest thank you for all your help hopefully in the near future persistence will be here. WB2K0
Hi Tim , We have spoken about persistence in the past and, actually you said the same thing to me. It's begin addressed. I know you do not write the software but i would appreciate if you could tell me on the road map where some sort of persistence will begin. The road map states some new features but nothing about persistence. Thank you Edward Armstrong WB2K0
I'll speak for Tim (and the company): Band and Mode persistence is scheduled for SmartSDR v1.1. This is in addition to the basic persistence included in v1.0 (see http://gsfn.us/t/47itt). Note that several issues were found in the transmit filter persistence, the last of which did not make it into SmartSDR Beta v1.0.5.0
Hi Eric thank you for explaining what's going on With persistence I am looking forward to When the radio remembers where it left off and power slider remembers the last setting and others Eric thank you very much once again.WB2K0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
