High temp readings and fan speed
Greg
I have a support ticket still pending on this. Has anyone else been experiencing hi temp readings and fan speeds when first starting the radio (6700)? DDUtil reports up to 165 degrees and stays like that for about 5 min then goes down to 30 degrees and the fans slow down. The radio is not getting hot during this and is happening just in RX...I am not transmitting. It does not happen all the time. Thanks Greg
Hi Greg, i never hear a fan speed of the my F6700, where you are saw this in DDUtuil 165 ?0
Yup....that be the place.
Curious though that on the setup screen for the 6000 tab there is a space for PA temp but it doesn't report anything there. 0 -
Hi Sergey. I think it is always a wise consideration to keep an eye on the radio's internal temperature. If I see it go above 60 I know to give it a rest, see what's wrong that is causing the high temp, reduce power...etc. 73 Greg0
Well, it is good, but this mostly the way to lost concentration on main functions in case allocation this on front page, but well appreciated somewhere in hidden menu0
No hidden menu. It is displayed on the main DDUtil screen. I keep that open below the SSDR window and just take a cursory glance at it now and then while I look at the screen or while transmitting. Not a distraction at all.0
27 inch enough for now :-)1
I like that way Al, Looks Good Ken W9IE0
I have closed this topic because a HelpDesk ticket has been opened. If you are experiencing erratic or exceptionally high temperature readings, please open a HelpDesk ticket for resolution.0
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
